Home > Faults & Fixes > Windscreen Washer
Cpthompson82
Windscreen Washer
Hi All
Newbie here.
Just picked up a 58 plate tdv8 sport hse which I am starting to "fix".
To be honest there's not that much wrong with it thankfully.
The driver side windscreen washer jet is only squirting out of one outlet and spraying all over out of the other.
I need to replace the washer but I'm strugglig to find them online in uk.
Then I keep seeing heated jets. How do I know if mine are heated?
If they aren't heated can I make them heated?
Does anyone know the model numbers?
They look like they should be easy to fit.
Thanks in advance.
Ps Should I get my lower plastics body coloured? It'll never be off road so unlikely to be damaged.
Post #342416 Thu May 03 2012 8:06pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi Cpthompson82
You may not have to change the nozzle for the washer, try first with a thin needle so unblock the
one that is blocked..
When water is standing for some time in the washer nipples, there will be some build of cruddy residue in them.
If that doesn�t help, then You can try to disconnect the hose from it, and blow backwards in it with compressed air, that ought to fix it.
Best regards
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #342417 Thu May 03 2012 8:12pm
