![]() | Home > Maintenance & Modifications > HVAC Blend motor. |
nicorobbo Member Since: 24 Mar 2010 Location: Stoke-on-Trent Posts: 9 ![]() ![]() ![]() |
Help! Drivers side heating/cooling is always hot irrespective of the temp setting.
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Got the same prob! Cold on driver side and hot on passanger side when bought on 23 degrees..
Hi
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
Blend motor you need is located behind the panel to the right of the passengers right leg, its a bloody nightmare to get to, i tried and gave up, will have another go at some point, imagine looking at the fromt temp dials, its behind and to the left and down about 12 inches.
Thanks for that.
Like this..?
oops soory my post related to the left side, yours is the drivers, bobbys post is spot on |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Bobby 1 Firstinretail 0 |
No problem.
