Home > Wheels & Tyres > Kahn 22" Wheels
tcc21
Northern Ireland 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Kahn 22" Wheels
Having just changed from A FFRR to a 2011 Sport, I dont know to much about them yet. Have got offered a set of Kahn Cosworth RS 10 x 22 ET 35 all round. Will these fit or with that offset are they for the wide body.
Regards
Post #340936 Sun Apr 22 2012 6:57pm
kahndesign
absolutely fine with those on the sport my friend. Thumbs Up
Post #340969 Mon Apr 23 2012 8:32am
tcc21
Thanks Martin, I just don't want them to fill the arches. From memory the RS wheels you have are 9.5 x 22 ET 40 or 45 and aftermarket wheels are 9.5 x 22 ET 45. That would mean mine would stick out by a further 22mm which seems quite a lot but you know best so I'll probably have a go at them. Is there and reason Kahn changed from 10 to 9.5 and different offsets.
Regards
Post #340986 Mon Apr 23 2012 11:19am
kahndesign
the et55 do sit fairly far in and to be fair are normally used on the FFRR rather than the sport although they do fit.
the et35 will sit as near as perfect as it gets on the sport. we do it every day. it will look good.
the offsets differ as some of the older sports and even the newer need lower offset wheels to clear the brembos.
teh Supercharged and the older TDV8 have Brembos which are failry big.
hope this helps you buddy.
anything else just gimme a holler Thumbs Up
Post #340998 Mon Apr 23 2012 1:16pm
