Home > General > Tow Bar Fitting
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Tow Bar Fitting
OK.....I have just received my tow bar in the post and have a couple of questions:
1/ How does the red blanking plate on the car come out of the female fitting?
2/ I can't turn the green locking lever on the tow bar even when it is in the unlocked position?
Advice anyone????
Jim
Post #340628 Fri Apr 20 2012 10:42am
red socket just tug it HARD
you have to pull the rotating green knob out from the towbar before it will rotate anti-clockwise to release.
You may find the "trigger pin" on the towbar has been sprung in transit... in that cvase you need to re-prime the towbar before it will locate into the socket.. RRS gone
Post #340630 Fri Apr 20 2012 10:47am
1. Just tease the red cover plate out, mine was in fairly tight first of all, a good yank (maybe with some long nose pliers) should sort that.
2. I can't remember the exact procedure, but if you look in the manual Whistle or on the Topix website there is a section called towing that shows you how to fit/remove the tow bar Thumbs Up ON THE WAY: BMW F21 M140i
Post #340631 Fri Apr 20 2012 10:51am
Endjin
Scotland
Also, they can be a bit of a swine to get fitted properly the first few times.
If your key won't come out after you've fitted the towbar don't try and force
it. It's just that the locating mechanisim is not quite seated properly and therefore
the towbar isn't 100% secure. I had to give mine a "friendly" Whistle tap with a
rubber mallet to get it to click in correctly the first couple of times. Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #340632 Fri Apr 20 2012 10:51am
jim4244
Thanks guys!
All fitted with no problems Thumbs Up
Jim
Post #340640 Fri Apr 20 2012 10:59am
Mine was a swine to fit the first time too. Ended up spending a few minutes fitting and removing it before it slotted nicely each time.
Had toyed with idea of using a little copper slip on it but decided I'd rather it was tight and secure than easy to fit and possibly loose. 2012 SDV6 - it's missing a couple of cylinders
Post #340654 Fri Apr 20 2012 12:11pm
