![]() | Home > Technical > Ride on my sport feels a bit hard? |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
could be too much pressure in the bags, is the ride height the same as yours? |
m22 gtr Member Since: 18 Apr 2011 Location: edinburgh Posts: 399 ![]() ![]() |
Can u adjust pressure in air bags? When both cars are together they look the same height. |
Strathearn Engineering Member Since: 23 Mar 2012 Location: Aberuthven PH3 1HE Posts: 65 ![]() ![]() |
It could be a multitude of things, from worn bushes to worn shocks...
Are you both running the same size of wheel & tyre combo? |
reason i asked the height was incase it had been calibrated incorrectly , so you can rule out the bags Could be Struts as mentioned although unless its crazy miles i wouldn't have thought it would be that Assume its got normal wheels?? |
The bags were put on by landrover specialist, both cars have 22" alloys and same tyres, the car has covered 70k miles, i thought it might be the bushes or dampners? |
22's do feel terrible on the sport in my experience but if your comparing it to your own car on the same wheels then it can't be that. As suggested it could be down to a number of things, get it booked in and checked out. |
