![]() | Home > Maintenance & Modifications > 2010 oil change between services |
I have not done it but hopefully THIS will help you! |
wullie Member Since: 27 Mar 2009 Location: Ayrshire Posts: 81 ![]() ![]() ![]() |
Hi Bobby
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Best thing to do is follow above, put 4,5ltrs of oil in then go for a short drive to warm the car. Switch off and leave on level ground for 10 mins then check the OBC oil level , it will tell you exactly how much more oil the car needs! Very clever. Oil and fiter change is around 5.8 litrs of oil. SVR 2018 in Santorini Black. |
HI TDV8HST
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
I have 10MY 5lt s/c, checked the oil level few days ago and it asked for 0.5L top-up. It's not a diesel and it should not ask for any oil as far as I am concerned.
Vadim, are you saying that in a petrol engine if the oil level is less than acceptable, there should not be a message advising how much oil to add?
No No Bobby. What I meant was that I never heard of any petrol RRS asking for oil in between yearly services. Hence I always thought adding oil to such engines is very unusual (in between services). So I am a bit concerned. Vadim A. |
Vadim ,what do you expect you thrashed it all the way to Kitzbuhel ! |
Sorry, my mistake. |
Monaco, and Zurich - several times! ![]() |
