Home > Technical > How to remove TDV6 2.7 STARTER MOTOR
anth 666
Hi new to forum, need some help with how to change the starter motor on a 2006 2.7 TDV6 RRS.
I removed the sump gaurds and eventually found starter but looks like a Censored to get out !!
Has anyone discussed this before with instructions or pictures please help if you can.
Thanks
Anth
Post #338547 Mon Apr 02 2012 8:52pm
Bobby
After removing the engine undershield, try this...
Release the fuel cooler.
* Remove the retaining bolt.
Release the fuel filter housing and support bracket.
* Remove the two retaining bolts.
Reposition the fuel cooler and the fuel filter housing and support bracket.
Release the battery positive cable.
* Remove the clip retaining bolt.
Remove the starter motor support bracket.
* Remove the four retaining bolts.
Release the starter motor.
Disconnect the battery positive cable from the starter motor solenoid
* Remove the terminal nut insulator
* Remove the nut
Disconnect the switch lead from the starter motor solenoid
* Remove the integral connector nut
Remove the starter motor Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #338560 Tue Apr 03 2012 1:44am
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
how about disconnecting the battery before you start the job
Post #338580 Tue Apr 03 2012 8:05am
anth 666
Thanks Bobby, It's allways better to get advice from someone that has done the job before. Bow down
I allways disconnect battery first anyway when working on electrical system Ronniet , but a good point for those that might not be technically minded.
Thanks guys
Post #338599 Tue Apr 03 2012 9:36am
anth 666
Last question Bobby are there only 2 bolts securing the starter through the back of the bell housing ?
Thanks
Anth
Post #338601 Tue Apr 03 2012 9:41am
Bobby
Sorry, yes..
you have to remove the two retaining bolts to release the starter motor. Malaysia Boleh!
Post #338635 Tue Apr 03 2012 1:30pm
anth 666
Thanks again Bobby. Thumbs Up
Post #338646 Tue Apr 03 2012 2:30pm
