Home > Technical > Low Coolant Level Alarm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Search for "low coolant" -- bad sensors have known to cause issue on both RRS and LR3. |
Fri May 19 2006 6:48pm |
Grommet you have a PM! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 19 2006 6:57pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
My coolant reservoir (with built-in sensor) was just replaced due to the same message, which first appeared several weeks ago. Since it was obvious there was no leak and the problem was with the sensor, I had this done with my recent scheduled service. |
Fri May 19 2006 11:00pm |
XXXAngelXXX Member Since: 03 Mar 2006 Location: Krautland Posts: 10894 |
a bit off topic but on all our Jags we had the same problem - after a while the sensor gives up
Sat May 20 2006 6:00am |
All fixed after a trip to the dealer, so far no sign of any leakages and no more alarms! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat May 20 2006 10:42am |
What did they fix, Tim? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Sat May 20 2006 11:25am |
They filled the reservoir up to the minimum level and gave me the remainder of the bottle of antifreeze already 50% diluted. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat May 20 2006 11:27am |
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 |
Tim, now you've got your FBH I bet you're the only one amongst us praying for a cold snap!
Sat May 20 2006 12:11pm |
I also had the Aircon fiddled with as the distribution seemed to be all the cold air to the drivers footwell and none to anywhere else! The problem with the FBH is testing that it is working OK!
Sat May 20 2006 1:34pm |
