![]() | Home > General > Anyone know of this registration number? |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
all criminals sound genuine...if it sounds too good to be true.....then its dodgy |
kahndesign Member Since: 17 Mar 2011 Location: Bradford Posts: 484 ![]() |
just do a hpi check matey, that will tell you all you need to know and if he has the change of plate certificate issued by dvla cross check the 2 and you will know more |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
The DVLA info for both registrations are as follows:-
Then again it could have a twin brother |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 ![]() ![]() ![]() |
Only way to tell would be to get the VIN number from him (on the dash below the windscreen, or a panel under the bonnet) and do a proper HPi check to see what reg it matches up to and then check it to the V5 too! If you Land Rover with that VIN they should also be able to confirm the reg number if left them with (so will either be YN57 or something else)! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
run away!! |
![]() ![]() ![]() 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black ![]() |
Del Boy Member Since: 02 Apr 2012 Location: Kent, UK. Posts: 5 ![]() |
Land Rover confirmed that the registration number: YN57 HWG matched with the VIN he gave me, however I found that and was all set to go and get it until yesterday, when he gave me the Reg No. G3 NCO. Drives: 2007 '57' BMW 730Ld SE Auto E66.
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 ![]() |
One car should never 'accidentaly' be another.......... especially if you are a private seller.
Perhaps he has put it on a private plate, G3 NCO comes back as insured as a RR Sport |
Registered at different times, G3 NCO is a 56 plate. Drives: 2007 '57' BMW 730Ld SE Auto E66. 2011 '60' BMW 520d SE Auto F10. On the hunt for a RRS. |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 ![]() ![]() |
Definitely leave it...... |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Could be a trader pretending to be a private seller and using an old advert and or picture etc.....
Couldn't it be that the private plate G3 NCO was on an 06-reg car, then fitted to the 57-reg car (YN57) and has since been removed to sell? Not that unusual...think you need to speak to the seller and ask for an explanation. - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
