Home > General > RRS Rear brake pads
poolie
2006 Range Rover Sport TDV6 HST Java Black
RRS Rear brake pads
Warning light popped up on dash im assuming its the rears as i changed the front plus new sensor around a month ago.
Going to do this myself but need to know if the rear pistons are the push back with a clamp type or the screw type were you need a special tool.
My calipers are non brembos if that helps. tia
Post #338127 Wed Mar 28 2012 9:40pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
I changed my front and rear pads last year, no special tool required. Just attach a pipe to the bleed nipple and undo the screw to release the pressure while you compress the piston. Don't forget to check the brake fluid level when you have finished the job! I guess you will need to change the sensor if it has activated the warning light.
Take a look at this write-up from one of the D3 site guys its very helpful.
http://www.disco3.co.uk/gallery/displayima...&pos=5
Jim
Post #338131 Wed Mar 28 2012 10:02pm
poolie
Jim
Thanks jim Wink
Post #338134 Wed Mar 28 2012 10:06pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
tell us more about the nipples Jimbo! Whistle Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #338139 Wed Mar 28 2012 10:29pm
