Home > Technical > Parking Brake Jammed On :(
Benidorm Mick
2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hey Guys. EPB is jammed on on 2008 RRS. AA guys here and says he may have to cut the cables to release. Sounds a bit extreme to me. Anyone got a suggestion... Need quick response please Cheers
Post #335896 Fri Mar 09 2012 10:41am
Endjin
Scotland
It's a known fault on the RRS. I'd get your local dealer on the phone ASAP before the AA monkey butchers anything and ask them if his solution is required. Either way your car is going to end up at the dealer for repair! So I would check before letting the AA guy potentialy add to your repair bill!! 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #335898 Fri Mar 09 2012 10:49am
SRE
Spain
I am sure Bobby had some info on this
http://www.rrsport.co.uk/gallery/thumbnails.php?album=666 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #335899 Fri Mar 09 2012 10:49am
SRE
Spain
Here you go, you use your jack hande on the end of the cable
Post #335901 Fri Mar 09 2012 10:54am
SRE
Spain
A little more info Thumbs Up
Post #335903 Fri Mar 09 2012 10:59am
Benidorm Mick
Thanks guys. Quality info as always. He's managed to get it released without the butchering bit. He seems to think the cables may be frayed inside the actuator but i read on here that the more likely cause would be dirt build up jamming the pads. Also is there likely to be damage to the components inside the actuator??? (Been doing the screeching noise when attempting to release the brake) Cheers
Post #335908 Fri Mar 09 2012 11:23am
Endjin
Scotland
Glad he didn't have to butcher the cables Mick.
It is possible that if you have tried to drive away and the EPB was on
it may have shattered the brake disks (it's designed to do this as a safety
feature). I'd get it checked out at your dealer or whoever does your
servicing just to be on the safe side. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #335932 Fri Mar 09 2012 3:05pm
Benidorm Mick
Update. Local mech stripped the rear discs off on Friday. Nothing seized in there but massive wear to drum. at least 3mm worn suggests that shoes have not retracted properly for some time. Tried the EPB again and still sreeching so they're taking the module off today. Anyone know whether the insides are servicable or are we talking about a new unit??? If so, any idea on cost?? Thanks as always for any input guys... Thumbs Up
Post #336152 Mon Mar 12 2012 9:31am
