Home > General > Weights???
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Weights???
Whilst fitting my anti theft wheel cover today I noticed that on each side of the car, at the rear, there are 2 weights which are free to swing.
What are these for?
Jim
Post #334902 Fri Mar 02 2012 7:12pm
mark hamster
hope some one comes up quick with a answer quick.! im baffled on this Rolling Eyes Rolling Eyes
Post #334903 Fri Mar 02 2012 7:18pm
mlines
There is a technical name for them and a technical name for what they do but I cannot remember it.
Everything has a natural frequency at which it resonates, rub your finger around a glass and it creates a noise at a certain frequency specific to that glass. Add water to the glass and the note changes.
The axles in the car have a natural frequency and, I guess, in the Range Rovers case this must occur at normal road frequencies. Therefore the weights act as harmonic dampers to change the resonant frequency away from any normal road speed.
If you do hit its resonant frequency then the results can be interesting.....
 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #334906 Fri Mar 02 2012 7:34pm
I believe they are harmonic dampers. LR will have identified a frequency, during development testing, at which the suspension will have been excited by road vibration (resonant frequency). Fitting harmonic dampers de-tunes the car so that the suspension vibration doesn't cause resonance in the chassis/body.
It's a small version of the system used in big buildings exposed to high winds or earthquakes.
(edit: just seen the above post. That's two votes for harmonic dampers then Thumbs Up ) 2012 SDV6 - it's missing a couple of cylinders
Post #334909 Fri Mar 02 2012 7:39pm
SVR575
They are the reason the RRS is so heavy! Laughing SVR 2018 in Santorini Black.
Post #334975 Sat Mar 03 2012 4:23pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Also why there are two large weights on the front Brembo brakes. Sons of dogs come hither and get flesh
Clan Cameron
Post #334993 Sat Mar 03 2012 6:57pm
