Home > General > Fitting k&N filter?
m22 gtr
Scotland
Fitting k&N filter?
I was thinking about changing stock air filter and fitting k&n to my 06 2.7tdv6 rrs, what's peoples thoughts on these? Anyone got one fitted?
Post #334715 Thu Mar 01 2012 6:46pm
I've used them on my last 2 land rovers.
I feel they add a bit more responsiveness at low revs but it may be pseudo . RRS gone
Post #334719 Thu Mar 01 2012 7:02pm
Kensta
Sorry Elliot I forgot to take that calliper pic for u mate il do it Tomoro. I've got a K&N on mine aswel, worth doing for the little cost mate Java black 2006
Post #334726 Thu Mar 01 2012 7:19pm
m22 gtr
Scotland
No worries Kenny, ye I think I will get one.
Post #334727 Thu Mar 01 2012 7:32pm
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Fitted one last week. Dead easy and good impact. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #334748 Thu Mar 01 2012 9:24pm
Alive Tuning
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Call me old fashioned, but an air filter is there to filter out particulates in the air. Have you ever held a K&N, or any other pleated gauze air filter up to the light, and looked through it? You can see some pretty big holes in there, and trust me they will let grit through!
Also, these pleated filters have quite a small surface area, and are very thin. As they start to blind, they become more efficient at filtering smaller particles, but less efficient at flowing the volumes of air required to run the engine.
They are ideal for certain racing formula, that don't mind the compromise of letting a small amount of dirt in. These typically would be racing on clean tarmac tracks, or water. A race engine can be stripped, cleaned, and rebuilt several times in a season, but you dont want to be doing this with your car, do you?
We only supply foam air filters, made by Pipercross, or ITG. These have three layers of foam, with different pitch sizes as the air flows through. The coarse layer is very thick, and can capture far more particulates than a K&N, and maintain exceptional air flow for much longer periods. Oh, and you absolutely can not see through them when you hold them up to the light! Mr. Green
If ITG are good enough for formula1, they're good enough for your range rover! Which race teams (other than Nascar) use K&N anyway? Feel the difference... Feel Alive!
Member of the "Causeway Grey MY14 RRS SDV6 HSE Dynamic" Owners Club.
Like Alive on Facebook...
[b]In house MAHA LPS3000 4 wheel drive Rolling Road.
Post #334829 Fri Mar 02 2012 11:49am
To be honest, the difference its going to make to your range rover sport is hardly worth the change. Confused
Post #334831 Fri Mar 02 2012 11:57am
Alive Tuning
Quite true, The difference in performance will be negligible, especially on a standard spec car. The people who say that have seen a performance gain are usually those who's old air filter was well past its use by date anyway!
I have customers who use their (highly tuned) Land Rovers in dusty climates, and I just tell them to use standard paper element filters, and change them more regularly.
The original spec paper air filter is capable of delivering good air flow rates when clean, and will give you pretty much the highest level of filtration. Feel the difference... Feel Alive!
Post #334839 Fri Mar 02 2012 12:34pm
But I get a free sticker too Mr. Green RRS gone
Post #334840 Fri Mar 02 2012 12:44pm
I ran one for a little while and noticed no improvement
And the £40 cost against OEM LR filters costing £8 iirc I could change it a few times between service and still save money
Post #334843 Fri Mar 02 2012 12:56pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
......also, I've heard from other forums that a K&N filter is classified as a mod which should be disclosed to your insurer Confused Question Carl
Post #334938 Fri Mar 02 2012 11:22pm
sherlock
Vbsc. Come in are we sheep or human Rolling with laughter TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #334941 Fri Mar 02 2012 11:56pm
