Home > Technical > Vehicle will raise when compressor cooled?
BIG DJ
I went with a mate on Saturday to look at a RRS. There was a problem with the suspension and it was coming up with the above message.
Any ideas what the problem could be?
Post #334089 Mon Feb 27 2012 11:14am
garrycol
Australia
A hot compressor? 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #334094 Mon Feb 27 2012 11:30am
Bobby
Most probably compressor has over-heated due to repeated height changes.
Raising/lowering of the suspension is suspended so as not to damage the compressor.
Everything should be normal once the compressor has cooled enough. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #334095 Mon Feb 27 2012 11:31am
BIG DJ
I tried to go in access and it wouldn't. Kept going up into off road saying lower once cleared obstruction
Post #334099 Mon Feb 27 2012 11:43am
Bobby
Maybe there is an obstruction under the RRS?
And since you kept on pushing the access button, that might have overheated the vehicle! Malaysia Boleh!
Post #334101 Mon Feb 27 2012 11:51am
ChrisP
or there is a pressure leak in the system and the compressor is having to run continuously to keep the pressure up to the desired height sensor signal. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #334109 Mon Feb 27 2012 1:12pm
has he lowered the suspension?
This would trigger the extended mode RRS gone
Post #334123 Mon Feb 27 2012 2:15pm
