Home > Maintenance & Modifications > Washer bottle
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
Washer bottle
Guys
Ive just topped up the water bottle and the water appears to be pouring out of the headlight washer jets....any ideas to cause
Post #332996 Sun Feb 19 2012 4:37pm
ChrisP
Perhaps there are check valves and these have been frozen and damaged and gone normally open without any pump pressure? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #332997 Sun Feb 19 2012 5:15pm
Supacat
Is it coming out of both sides?
Post #333000 Sun Feb 19 2012 5:41pm
ronniet101
coming out of both sides equally fast
Post #333107 Mon Feb 20 2012 12:39pm
Bobby
Maybe its the headlamp washer relay which is located in the Battery Junction Box. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #333110 Mon Feb 20 2012 1:19pm
ChrisP
So an electronic valve rather than a check valve,wouldn't the pump have to be on too? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #333116 Mon Feb 20 2012 1:38pm
ronniet101
the pump is definetely off...the water just pours out of the jets on both sides, first time its happened, thought it might be a pump problem or a valve problem, but one way valves normally stop the water coming back not going out....
Post #333145 Mon Feb 20 2012 3:42pm
ChrisP
I've no idea whether its mechanical valves or electronic but cars I've had before have check valves which only allow flow out once the pressure is over say 5psi,if these went they went OC so let water through at low pressure,just a guess really that there may be frost damage.
There is some kind of valving because on mine the headlamp wash stops when the water bottle is running low to preserve water for the windscreen. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #333171 Mon Feb 20 2012 4:54pm
Texstar
It must be the pump (as said, possibly has frozen at some point, and is now damaged internally), there are no separate valves,just an open pipe to the nozzles. The level sensor stops the h/l wash pump operating when the level gets low to preserve some for screenwashing.Pumps are not that expensive and can be got at behind the N/S front wheelarch liner(fwd of the wheel). Thumbs Up RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #333183 Mon Feb 20 2012 5:30pm
ChrisP
So there are 2 separate pumps,1 for HL and a separate 1 for the WS? MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #333195 Mon Feb 20 2012 5:56pm
Texstar
Yes,there are 2 separate pumps ,from memory the h/l wash pump is the bigger of the 2. Wink RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #333197 Mon Feb 20 2012 6:02pm
ChrisP
Sounds to me like the HL pump has been frozen and water is just running through under gravity then Idea MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #333208 Mon Feb 20 2012 8:30pm
ronniet101
thanks for the help guys....will check again when i top bottle up to see if its still happening, otherwise it looks like a pump change
Post #333251 Tue Feb 21 2012 9:33am
