Home > In Car Electronics > What Bluetooth works best with RRS? Don't think my HSE has
B14RYW
I have a 55 plate RRS TD HSE
I thought my car came with Bluetooth but I have no controls on the under side of the steering wheel like my friends 2005 supercharged RRS
So now I am wondering if I even have it!! I thought the HSE model came standard with it tbh
If it doesn't, how can I add this? Would I need to get the steering wheel with the controls?
Failing that, does anyone use a Parrot kit or another for incar or hands free?
Any advice be appreciated
Post #329623 Thu Jan 26 2012 11:46am
Bodsy
Site Sponsor
if you don't have the green/red buttons, thenyou don't have it......
You can retrofit it though.
Sames as the D3 retrofit. Have a look at these threads
http://www.disco3.co.uk/forum/topic53302.html?highlight=blutooth
http://www.disco3.co.uk/forum/topic53544.html?highlight=blutooth
Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #329625 Thu Jan 26 2012 12:04pm
Freud
Netherlands 2007 Range Rover Sport TDV6 HSE Java Black
Bleu tooth
My RRS 2007 fails to connect 8 times out of 10 with Bluetooth on my Blackberry Torch. Anybody any suggestions other then throwing the phone in the bin ( it also has the problem with other Blackberrys)
Post #331737 Thu Feb 09 2012 7:14am
AZIZBBU
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Re: Bleu tooth
I had similar problems, i had the latest software on it which was causing the problems.
Was informed by a fellow forum member to downgrade my software (bundle 695, platform 6.4.0.105), it then works perfectly.
Aziz Thumbs Up TDV8 HST STORNOWAY ON A 58
Full Alpine multimedia install
Road Angel Pro
PS3
Post #331739 Thu Feb 09 2012 7:21am
Freud
You are probably right i had upgraded the software on my Blackberries just 1 month ago. Can i downgrade the software from the Blackberry website or do i need to find another site?
Thamks for the answer.
Post #331740 Thu Feb 09 2012 7:27am
AZIZBBU
Yes it can be done from the BB site Thumbs Up TDV8 HST STORNOWAY ON A 58
Road Angel Pro
PS3
Post #331742 Thu Feb 09 2012 7:30am
Freud
Thnx mate!
Post #331744 Thu Feb 09 2012 7:32am
Bodsy
Site Sponsor
And if that doesn't work, this should....
http://www.disco3.co.uk/forum/topic53544.html?highlight=Blutooth Bodsys Brake Bible
See it HERE
Post #331802 Thu Feb 09 2012 11:31am
Freud
Wow! Looks like a lot of work! I am going to try the software first. Thank for thr thread.
Post #331803 Thu Feb 09 2012 11:34am
