![]() | Home > Technical > Placed jack in wrong location |
Very common to damage the compressor - do a search and you will get an idea of price Mike
Katrina999 Member Since: 23 Sep 2011 Location: Ayrshire Posts: 13 ![]() ![]() ![]() |
can't find anything in the search to say whether it's safe to drive or not ?? anyone any idea or should I get it recovered ? I did drive it today and the compressor sound came on when I first started the car not every time but lasted about 1 minute then went off again... |
I did the same a couple of weeks ago - sounds as if the compressor is all OK and working as it should - the air compressor is just topping up the air tank and will most often do it for a while on start up . The reason you can here it is because it is most likely the mount is damaged and the insulation cracked - should be OK to drive but it need to be checked and fixed quickly.
dazsear Member Since: 23 Nov 2008 Location: Lincolnshire Posts: 851 ![]() ![]() |
The compressor is attached to the car by an alloy bracket which almost always snaps under the weight of the car if used as a jacking point.
yep bracket is knackered and it seems one of the pipes has gone too |
