Home > Maintenance & Modifications > ECU REMAP
Tim Hoang
ECU REMAP
Hi All,
My car was remapped about 3 three years ago, everythings were perfect till few months ago I blanked the EGRs and noticed that the engine need higher rev. and reduced fuel economy. The question is: Do I need the ECU remap again? OR else. Thanks. 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #331229 Mon Feb 06 2012 12:53am
Johnnyopolis
Re: ECU REMAP
Tim Hoang wrote:
Hi All,
I thought this was normal when you removed the EGR valves?
Post #331230 Mon Feb 06 2012 1:05am
Tim Hoang
I know but its not as normal. Also as far as I know that when remap, the software monitors everythings (air, gas, etc.) for top economy and speed. So when you blanked EGRs you actually alter the incoming air into the engine ie. the ECU should be rewritten. Correct??? 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #331362 Mon Feb 06 2012 8:46pm
