![]() | Home > Technical > Air Compressor |
chesterfield Member Since: 14 Jul 2011 Location: Chesterfield Posts: 123 ![]() ![]() ![]() |
I have the exact same fault on the dash and the car is in tomorrow for a new compressor.
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
Hi Chesterfield,
No idea about reconditioned compressor, but I believe it can be done diy as i read a guide on replacing the compressor just the other day, though this could have been an older model FFRR. I assume the concept is still the same though, its only a couple of wiring plugs and some air lines.
DrLex Member Since: 21 Nov 2005 Location: Ciderspace Posts: 257 ![]() ![]() |
If you have a leak (be it hole in "bag" , line or faulty valve), then your vehicle will be lower than normal after being left overnight (assuming it wasn't left in access mode).
That would explain the relay being replaced on mine too.
Where is the relay located?
It's in the battery junction box in the engine compartment.
Blimey. That looks far too complicated ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
car back, relay and compressor replaced. Touch wood no reoccurance of the problem yet. However there were days when it workd without a problem even while it was suffering the fault, so may be too early to give a conclusive fix. RRS 3.0D HSE 11MY - Fuji White, a few extras. |
