![]() | Home > General > UK front license plate frame |
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 ![]() ![]() ![]() |
Number plate goes on with either double sided tape or a self tapper either side of the plate |
buster04 Member Since: 28 Jan 2012 Location: Philadelphia, PA Posts: 3 ![]() ![]() ![]() |
thank you. |
mrobbie Member Since: 23 Jan 2011 Location: London Posts: 102 ![]() ![]() |
...and be careful when removing the front plate on a cold morning if it has been stuck on with the double sided foam. Liklihood is that you will end up holding a plate and hald a mounting frame. |
^^^ Good point |
wish I knew that last Friday morning |
^^^ oops |
