Home > Off Topic > Tools Explained the US way
Buster007
Tools explained.
1. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings your
beer across the room, denting the freshly-painted project which you had
carefully set in the corner where nothing could get to it.
2. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light . Also removes fingerprints and hard-earned
calluses from fingers in less than the time it takes you to say, 'Oh Censored !'
3. SKILL SAW: A portable cutting tool used to make studs too short or electical
cords a smaller length. Name does not necessarily imply the intellect of the
operator.
4. PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
5. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up
jobs into major refinishing jobs.
6. HACKSAW: One of a family of cutting tools built on the Ouija board
principle... It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your future
becomes.
7. VICE-GRIPS: Generally used after pliers to completely round off bolt heads. If
nothing else is available, they can also be used to transfer intense welding
heat to the palm of your hand.
8. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub out of which you want to remove a bearing race.
9. TABLE SAW: A large stationary power tool commonly used to launch wooden
projectiles, testing the integrity of nearby windows. >
10. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you
have installed your new brake shoes, trapping the jack handle firmly under the
tire.
11. BAND SAW: A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the trash can
after you cut on the inside of the line instead of the outside edge.
12. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
13. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or
for opening old-style paper-and-tin oil cans and splashing oil on your shirt;
but can also be used, as the name implies, to strip out Phillips screw heads.
14. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws and butchering your
palms.
15. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket
you needed to remove in order to replace a 50 cent part.
16. HOSE CUTTER: A tool used to make hoses too short.
17. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used
as a kind of divining rod to locate the most expensive parts adjacent the object
you are trying to hit.
18. UTILITY KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door, but works particularly well on the contents, such
as seats, vinyl records, liquids in plastic bottles, collector magazines, refund
checks, and rubber or plastic parts. Especially useful for slicing work clothes
or appendages, but only while in use.
19. BREAKER BAR: used to remove the heads of bolts in places not accessible by the drill needed to extract the rest.
20. SON-OF-A-BITCH TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a BITCH!' at the top of your lungs. It is also, most often, the next tool that you will need.
Hope you found this informative. Cheers Laurence.
Post #329835 Fri Jan 27 2012 9:36pm
panda
Laughing Laughing How true they are. Laughing Laughing
Post #329870 Sat Jan 28 2012 10:49am
