Home > Technical > Fog lights blowing fuses...
Jmac
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
As above, now it's foggy, tried to use the front fog lamps and noticed they didn't work.. Replaced the 15a fuse and they worked for 5 mins then stopped again..
Where should I start checking?
Cheers,
J
Post #328634 Wed Jan 18 2012 8:16pm
CycleSi
Almost certainly a broken/damaged wire behind one of the fog lights - it's very common and easily repairable.
Same happened to mine just before Xmas so we popped both lights out and fitted some heat shrink and insulation tape around where the wires had rubbed through on the bumper/body work.
Sorted.
Post #328670 Wed Jan 18 2012 10:05pm
Jmac
Brilliant- thanks.. Will sort that this weekend..
Cheers,
J
Post #328677 Wed Jan 18 2012 10:35pm
BulletProofBomb
+1.
Mine was the wire also, have a look at this.
http://www.disco3.co.uk/forum/topic27135.h...+%2Blights
Very helpful. Thumbs Up RRS TDV8 (loving it)
Suzuki Bandit 1200 (For when the suns out)
Nissan 350z GONE
Post #328695 Thu Jan 19 2012 4:37am
