Home > General > How hard do you push before your ETC kicks in??
felstmiester
United Kingdom 2005 Range Rover Sport TDV6 HSE Santorini Black
I haven't owned a RRS before so I'm not sure how eager the traction control is to kick in but mine is terrible!!
Now I'm not sure if I have a problem because although it hasn't been noticeable in the 7 months of owning it until now, but then again the weather is Censored and the roads are I guess a lot slippery.
What I'm finding, is when I turn into a right hand bend at moderate speed the traction kicks in something terrible. I would say it's definitely worse on right handers. Now I thought it might be something to do with the tyres I had on my old 19's, but now I've got a set of 22's with brand new tyres and it's still doing the same thing. I know the range rover is a heavy car so throwing it into a corner hard is going to upset it, but I'm talking at slow speeds.
Thought maybe something is wrong with the nearside suspension but I've had the wheels off and checked everything but all seems ok. Has anyone had anything similar ?
Post #328611 Wed Jan 18 2012 6:04pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
this wont help but there is a thread where a guy had this happening and something was wrong - I can't remember what! either flat tyre, or stuck parking brake, or something like that ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #328618 Wed Jan 18 2012 7:00pm
felstmiester
Done a search but can't find anything.
Post #328655 Wed Jan 18 2012 9:34pm
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Again I know this doesn't help, but I can fling mine about and into corners pretty hard without interference.
Doesn't sound right what u got going on there Sad Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #328656 Wed Jan 18 2012 9:38pm
felstmiester
Yeah, I guessed there was an issue with mine, and it's not a under inflated tyre and the brakes are definatley not binding.
Post #328659 Wed Jan 18 2012 9:44pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
If the steering sensor is out (ie the car doesn't correctly identify the turning angle of the front wheels), it can cause the DSC to activate and pull the car into what it thinks is the correct line. This can often happen preferentially towards one direction or the other. Try switching the DSC off and see if it still does it.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #328690 Thu Jan 19 2012 12:00am
garrycol
Australia
I agree with Gordon - this is the Directional Stability Control (DSC) doing its job - it is not the Electronic Traction Control - the clue is that it is happening when you are turning. Assuming all is well in the car it would indicate you are cornering too fast for the corner and the car is beginning to shift6 weight and slide (you may not feel it) and the DSC is picking it up and correcting. Last week I was turning a corner at about 50kph in the dry and dsc kicked in - I later found I had a flat rear passenger side tyre. In the corner the tyre was down but not flat and the car must have rolled a bit on the flat (not noticeable by me) and dsc picked this up.
Try driving a bit slower for the conditions Cool
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #328691 Thu Jan 19 2012 12:24am
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Traction/stability control won't help in slow speed understeer, there are one or two roundabouts near me I have to be careful at, you come up to them cruise round with foot half off the gas and front looses grip, in my case I would say tyres are not at their best despite only being half worn, if you are running new 22s I would think the compound is probably harder/sidewalls not having as much give, which is causing you to understeer
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #328707 Thu Jan 19 2012 6:28am
felstmiester
So from what you guys are saying there's nothing wrong with the dsc on mine, it's just the fact it's doing it's job?
Post #328800 Thu Jan 19 2012 5:12pm
rrsboy
i wouldn't be so sure
"What I'm finding, is when I turn into a right hand bend at moderate speed the traction kicks in something terrible. I would say it's definitely worse on right handers. Now I thought it might be something to do with the tyres I had on my old 19's, but now I've got a set of 22's with brand new tyres and it's still doing the same thing. I know the range rover is a heavy car so throwing it into a corner hard is going to upset it, but I'm talking at slow speeds."
I can't remember the last time I felt the DSC and I drive mine... um... with enthusiasm Thumbs Up
possibly a dicky sensor? but not dicky enough to throw up an error message/light ============
Post #328801 Thu Jan 19 2012 5:14pm
felstmiester
So where is the dsc sensor located?
Post #328805 Thu Jan 19 2012 5:30pm
felstmiester
http://www.warrantyguide.co.uk/vehicle-rec...ted-with-d
Although mines a 55 you never know.
Post #328807 Thu Jan 19 2012 5:34pm
rrsboy
now for that you need Bobby!
I suspect it uses many inputs - steering, wheel speed, directional etc ============
Post #328808 Thu Jan 19 2012 5:34pm
disco4x4au
The DSC module takes multiple sensor outputs for it's own data input - yaw, acceleration, steering wheel angle etc. If this is something that started recently, has anything been changed/repaired/recalibrated in the front end of the car?
It's not necessarily a sensor issue - worn bushes or tyres, bent arms or steering rack can affect the DSC too.
Cheers,
Post #328870 Fri Jan 20 2012 1:45am
Jonathan
England 2012 Range Rover Sport SDV6 Autobiography Fuji White
I had this before. What tyres are you running? I had 22" wheels when I first got mine with non premium brands and it caused the dsc to come on in corners, I thought I was just pushing the car too hard but it was def the tyres.
Hope this helps! Jaguar XKR Convertible
MY 2012 Range Rover Sport TDV6 Autobiography in Fujian White....Mmmmmmm
Range Rover Evoque 2.2 Prestige in white - gone
Porsche Boxster S White with lots of extras! Gone
Lotus Elise 2011 Touring for sunny days - gone!
Previously....
RRS TDV8 Black 57 Plate
645ci
Jag XKR Convertible (my wife still loves this car!)
BMW 530i
BMW 328i (I loved this car)
Golf R32
Post #328871 Fri Jan 20 2012 7:11am
