Home > Technical > check brake pads light |
NickM Member Since: 14 Feb 2008 Location: London Posts: 2995 |
Be thankful the sensor has come on...sometimes the sensor on the side that hasn't worn as much won't come on at all, and even when you're down to metal on metal.....the sensor is tellin you you're close, so listen before its too late..... |
Sun Dec 25 2011 5:13pm |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
just have a look, my sensor fell out, bought new discs and pads and then relised they didnt need changing duh !! |
Sun Dec 25 2011 6:57pm |
It won't re-set until you put a new cable on. But you don't need to hook it up to a machine or anything.
Mon Jan 09 2012 2:58pm |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 |
There'a only one sensor between both sides so no surprises the other one doesn't come on! I think the sliding caliper design is more prone to uneven wear across the two pads. The oposed piston design seems much better. Shame on LR for down spec'ing on the TDV8 from the Brembos. |
Tue Jan 10 2012 9:56am |
