Home > Technical > washer bottle problem??
mark hamster
hi all another one for you..! going to work yesterday,i squirted water onto windscreen but noticed it only came out of one side and was very bubbly,so thought bottle getting low.? on way to work today and message came up low washer bottle or something like that.? so at work i have filled up washer bottle to top,but when i press button,NO water what-so-ever coming out but its making all the noises like it should.! any ideas please Bow down Bow down also no water coming out onto lights Bow down Bow down
Post #327352 Sun Jan 08 2012 10:56pm
Supacat
It just sounds like you are completely emptied the system and you need to to give the pumps time to pump back into the tubes before anything comes out the jets.
Be patient and try for a little longer.
If this does not solve it then it sounds like you have an issue in the tank as the windscreen and lights work off independant pumps and hoses. You may have dislodged some debris that is blocking the outlet(s).
Post #327394 Mon Jan 09 2012 9:05am
A hose might have come out or degraded. 2005 Zambezi TDV6 - Gone but not forgotten
Post #327395 Mon Jan 09 2012 9:08am
mark hamster
worked it out today.! took off both pipes and water coming through,so put back on and stuck a pin in washer jets and wiggled around and now all ok.! think it might off pulled through a load of crap in bottom of bottle.! thanks for reply's guys Thumbs Up
Post #327437 Mon Jan 09 2012 1:56pm
