Home > Maintenance & Modifications > Side Step Fitting ?
beefbops
Scotland 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Side Step Fitting ?
Hey all, new to the forum here and im looking to fit some side steps, have seen them on ebay, but not sure whether to get the ones that come with cut sills or just buy the steps and try and cut my own.
Has anyone fitted there own, cut there sills, any tips/advice would be brilliant.....
Cheers Beefbops Thumbs Up
Post #327034 Thu Jan 05 2012 8:11pm
Hi and welcome to the site Thumbs Up
This link will tell you all you need to know, with instruction video , i'd recommend pre-cut sills, you can get them for £210 off e-bay with pre-cut sills.
http://www.powerfuluk.com/products/range-r...p-kit.html
Post #327048 Thu Jan 05 2012 8:53pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Side Steps
Hi, just wondered how you got on with your steps?? Bought a RRS last week and then a set of side steps from e-Bay. The steps look to be good quality but have no fitting instructions and no template for the sill cut outs. I've downloaded the instructions from the LR site so no problem there but I'm unsure about the cut outs for the sill. I was told that there are markings on the sill for the cut outs but if anyone can confirm whether this is the case or not it would be much appreciated.
Post #329047 Sat Jan 21 2012 8:20pm
beefbops
Re: Side Steps
Hi Tony, they are simple to fit mate, a bit time consuming but no bother. I actually orderd the set with the precut sills, you can actually get them for the same price and same quality.
Post #329638 Thu Jan 26 2012 1:10pm
Stuart's the man
when you take the sill covers off they are marked on the inside with the cuty out holes
Post #329893 Sat Jan 28 2012 12:13pm
Tony666
Thanks guys, sidesteps now fitted, not too bad a job but my sills didn't have the markings on. Not too much of a problem as the cut out dimensions on the Land Rover site worked fine. Easy enough to cut through the plastic with a hack saw/sharp stanley blade. Onto the next two jobs now, front parking sensors and rear door latch mechanism, wish me luck!!!!!! Rolling Eyes
Post #329904 Sat Jan 28 2012 12:47pm
Tony666
All Done!!!
Well that's the sensors and door latch assembly sorted. Sensors not too bad just have to remove the bumper but the door latch a bit fiddly and I managed to damage my speaker in the process Sad If anyone's going to attempt this there is some good info on the disco3 forum, and I'd be glad to give any advice if it would help. Now then, what's next??? (Anyone got a Harmon Kardon standard speaker for sale??)
Post #330747 Fri Feb 03 2012 12:09am
