![]() | Home > Technical > Nuts |
Bobs_buggy Member Since: 30 Apr 2006 Location: Pump No.3, usually! Posts: 213 ![]() ![]() ![]() |
Hmmm..........
pjc999 Member Since: 27 Mar 2006 Location: London Posts: 4 ![]() ![]() |
Cheers Bob. Yep - was actually looking for a way to keep the wheels on rather then taking them off! When I lost the M3 wheels, it was actually a case of the thieves having a copy of the standard BMW key. A bit like the M5 crimewave that is currently happening.
You have my deepest sympathy. I'd be devastated if that happened to me (although I'm actually in the reverse situation at the moment........I have the wheels and tyres in the garage, but no car to fit them to yet!).
When my wheels got nicked off my BMW it only had about 40 miles on the clock and they had the same thing. Copy of the BMW set (been told that there are 23 different set that BM have
Great until you get a flat tyre! Will let you all know once I've tracked a set down. |
The biggest deterent to stealling 4x4 wheels is the sheer weight of them, these things are huge and very heavy which means it takes Mr Stcky Fingers a lot longer to whizz them. Ask SuperT, he recently changed 4 wheels and suffered the next day for the pleasure of putting 20"ers on 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Supertrotter Member Since: 10 Mar 2006 Location: Brrrr.... guess where :o( Posts: 9905 ![]() ![]() |
Tim is absolutely spot on.
ST, I've got all that to look forward to. I'm going to swap the 20" wheels for the Stormers as soon as I get the car home.
OR INVEST IN THE PROPER TOOLS TO DO THE JOB!
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
I bought a non BMW set of wheel locking nuts for the wife's Z4, they came highly recommended and you can get them from halfords, made my McGards. The set of four cost £18 or so, was worth it. They may do a set to fit.
Isma Member Since: 08 Apr 2006 Location: Miami, FL Posts: 26 ![]() ![]() |
Fitted a set of standard wheel locks about 2 weeks ago, and will be looking for a second non-LR set soon.
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
and then - when really frustrated ..................... stanley knife all the way down the side of the car |
But I know where your coming from |
Ah, you've just reminder me to get one of those high lift trolley jack jobbies. My trolley jack won't reach a 4x4 without using blocks of wood (not recommended). Can anyone recommend a jack that fits? I believe there is a hole in the 4 chassis corners to fit the stud from the jack. I'll need to buy a trolley jack with the same size stud. I've got the air tools, so that should save a bit of grunting, but those Stormer wheels are heavy. Has anyone compared the weight to the s/c 20 inchers? Unsprung weight is always a bad thing when it comes to suspension tuning. I'd have thought they'd try to make them lighter as they get bigger (and more "sporty"). Bob. RRS 4.2 S/C. Zermatt. Tints. Stormers. 150+ paint defects, wonkey bonnet, scratches, detached doorseal. suspension faults. To sum it up, a �60k pile of cr4p! |
