![]() | Home > General > Smart Key / Battery Low |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello
If you need to replace it, here you go |
Also is possible to replace battery, but you need to buy a new key case as you destroy the old one, to open it. Also the battery is PCB mounted so needs a bit of soldering. Fairly easy, did one of mine about 8 month ago. Not because the battery had gone, just did it to tidy the key, but replaced battery at the same time.
Shepp, the above is from the 2010 manual, so I would say X5, can just swap in a new battery, no need to destroy the case |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
pre 2010 --> key should recharge while in ignition... replacement of the rechargable battery through dealer I assume...
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
Sorry I meant the thick key |
^^^ Is that not your key style in the picture I linked above ? If it is, batteries are easy to get from amazon/ebay/dixons etc ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
cheers mate im on a client site today and the picture didnt come up due to a policy on their webfilter, Got it on my Iphone |
Ah, no worries ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 ![]() ![]() |
I have opened 1 of my keys to attempt changing the battery.
No personal experience, but a quick search on here, suggests that on the older key fobs, yes, you do have to remove and then re-solder a new battery in to the PCB. ON THE WAY: BMW F21 M140i
