Home > General > Why doe land rover not offer a 20" spare option?
swalker900
Sorry if this has been covered before, but I couldn't see any other threads!
So why can you not specify 20" spare as an option? Is it something to do with directional tyres maybe? MY2010 3.0 TDV6 HSE, Zermatt silver/Ebony/walnut, privacy, side steps, rubber mats and standard otherwise...
Post #326621 Sun Jan 01 2012 7:43pm
mlines
most likely its because there is not enough room for it. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #326626 Sun Jan 01 2012 10:29pm
simon1233
20 inch wheel will fit under the car, both 19 & 20 have the same rolling diameter.
I would assume that economies of scale was the main driver for all disco and RRS having a 19 inch spare
Post #326642 Mon Jan 02 2012 7:59am
Why would you want a 20inch spare? Unless you plan to rotate your spare out on to the car, it would be fairly pointless. The 19inch will suffice for the trip from puncture to tyre fitter for a repalcement main tyre. And for quite a large number of RRS on the road, the supplied wheels would have been 19inch all round. So LR would need to source a 20inch as well. Which would put the price up I guess. 2012 SDV6 - it's missing a couple of cylinders
Post #326647 Mon Jan 02 2012 9:25am
swalker900
Just buys a bit more time to source a repair/new tyre if on hols in the alps etc.
All new hse uk spec upwards RRS from my2010 come with 20" standard, so there are plenty of 20" wheeled cars out there.
Just thought that land rover wouldn't have a problem offering a full sized spare as they do with new freelander 2 cars, as an option - unless there was size issue (tyre width etc)?
New 20" single wheels are found in plentiful ly on fleabay, so thought I'd check before buying one Wink MY2010 3.0 TDV6 HSE, Zermatt silver/Ebony/walnut, privacy, side steps, rubber mats and standard otherwise...
Post #326649 Mon Jan 02 2012 10:28am
Bob.
Further discussion here:
http://www.rrsport.co.uk/forum/topic16742.html?highlight=
Bob
Post #326683 Mon Jan 02 2012 8:44pm
Supacat
and in summary for me a wider wheel/tyre combo will hang lower and potentially be prone to damage.
Post #326726 Tue Jan 03 2012 11:06am
I've had so many cars now with either 'space saver' or different spec spare wheels, I'd not even thought about upgrading to a 20" alloy to match the rest.
Given the 'on show' location of the spare on the RRS, I think that having a bog standard 19" is just fine Smile ON THE WAY: BMW F21 M140i
Post #326728 Tue Jan 03 2012 11:10am
mlines
But not the same width (depth)? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #326745 Tue Jan 03 2012 3:02pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
This must be one of those quirky Landrover things.
My D4 came with 20 inch wheels fitted and spare is a 20 inch as well Question Exclamation Question
Perhaps its to keep the profit margins up on the RRS Now driving a rather smart looking Van
Post #326786 Tue Jan 03 2012 8:57pm
mse
Cost, Space hanging below and im sure its an option Mike
2014 Facelift Discovery
Post #326787 Tue Jan 03 2012 9:05pm
Bob.
Is it all to do with LR brochure quoted departure angle which is important for off roading?
To be able to quote the maximum departure angle the first thing to hit the ground when you go from level to a steep incline must be the rear bumper rather than the spare wheel.
My 07 TdV8 came with 20" road wheels and a 19" black spare. The spare was fitted with a 255/50x19 tyre and is actually a Disco wheel which is 1" narrower than a standard 19" RRS road wheel.
Just to add to the confusion, a D4 20" carries a 255/50x19 tyre and the rim is 8.5" wide. A RRS 20" carries a 275/40x20 tyre and is 9.5" wide so a 20" D4 spare will not hang as low as a 20" RRS spare.
To add to the confusion - why do LR specify 255/55x19 winter tyres rather than standard 255/50x19 for RRS. Question
Post #326809 Wed Jan 04 2012 9:56am
