![]() | Home > Tips & Tricks > Continental 275/40 R 20 Tyres |
Interesting - hadn't herd that one before. Thanks. 2005 Zambezi TDV6 - Gone but not forgotten
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
sworks Member Since: 28 Nov 2010 Location: Inverness Posts: 5 ![]() ![]() ![]() |
Just got a full set replaced at 14500 miles, shoulder tread had started to wash out, have replaced these with Pirelli |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Which Pirelli did you go for? I'm looking at what to put on next to replace the Goodyear Wrangler F1s that mine came with. They're ok in the dry but don't seem to like standing water very much. 2012 SDV6 - it's missing a couple of cylinders
V8 andy Member Since: 11 May 2009 Location: east yorkshire Posts: 540 ![]() ![]() ![]() |
If your fitting conti's you need the 106Y XL,,,,,NOT the 106Y NO.
flydive Member Since: 17 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I'm carefully avoiding Continentals for the RRS, so not an issue |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
need to look at this,just changed mne round |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 ![]() ![]() |
Got a new set sitting in garage must have a look before I put them on wheels |
RRS-Spy Member Since: 01 Nov 2011 Location: London Posts: 169 ![]() ![]() ![]() |
All Porsches have specific tyres made by the various tyre manufacturers. They are only for Porsche cars and are recongnised by the marking. N0, N1, N2, N3 etc
checked today on the new set in garage and they are xl |
Have to say that I'm surprised anyone with more than a passing interest in cars didn't know any of this...
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Are you aware of LR publication on this issue: Issue. A customer may report uneven tyre wear on vehicles fitted with 20 inch wheels and Continental 4x4 Sport Contact tyres. Cause. With reference to the photo attached, Due to the tread pattern design of this tyre, there can appear to be inner or outer shoulder wear. This is in fact just the natural tread wear, but as the design of the lateral grooves continues around to the sidewall, the very ends of the grooves do not wear giving rise to a "band" of wear at the edge of the contact patch. Action. No action is required for this issue as it is deemed a characteristic of the tyre and not a fault.
Having said that there was an earlier TSB - No.LS204-009V2 A customer may report a concern of uneven tire wear. Cause: Certain vehicles may experience a degree of 'bush settle' after the initial geometry setting following production (this has now been compensated for using calculated geometry settings introduced from the VIN above). This 'bush settle' may change the geometry settings to outside of normal tolerance and may increase tire wear. This issue is not experienced on all vehicles and the toe sensitivity may be attributed to other factors. Action: Should it become necessary to adjust vehicle geometry due to specific complaints of tire wear, or where the components detailed below have been changed, the geometry should be set to the target values detailed in this bulletin. These target values are within the geometry specifications detailed in the workshop manual but are purposely detailed to address the above concern. Target Values Adjustment Specification (degrees/minutes) Front total toe 0° 02' Left-hand rear toe 0° 11' Right-hand rear toe 0° 11' Rear total toe 0° 22' NOTE: The air suspension tight tolerance mode should be activated when checking/setting geometry (refer to the procedure on GTR). Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Had this in my Gallery sometime back...
Bobby - my apologies - that's probably where I data mined it from some time ago |
