Home > General > 2012 rr sport
skywriter
2012 rr sport
should the fuel flap lock when you lock the doors
Post #326367 Wed Dec 28 2011 10:30pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
In a word, yes!
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #326371 Wed Dec 28 2011 11:48pm
skywriter
thank's mine's not
Post #326373 Thu Dec 29 2011 12:23am
As codfather says, yes. Smile
Edit: I just checked when I popped out to the garage, the filler flap is definitely locked. ON THE WAY: BMW F21 M140i
Post #326374 Thu Dec 29 2011 1:00am
Supacat
The fuel filler door lock actuator extends and retracts a wire reinforced plastic pin to lock and unlock the fuel filler door.
In an emergency, the fuel filler door can be unlocked by manually retracting the actuating rod on the actuator. The actuating rod can be reached through the access cover in the rear quarter trim.
If the fuel filler flap is forced open, the latch will release from the filler flap door without causing damage to the door.
Post #326409 Thu Dec 29 2011 12:55pm
mse
Apparently it only locks when the car is deadlocked...have you checked it is deadlocked Mike
2014 Facelift Discovery
Post #326415 Thu Dec 29 2011 1:10pm
^^^ unfortunately not, I just checked mine and it locks the filler flap on both normal and deadlock. ON THE WAY: BMW F21 M140i
Post #326416 Thu Dec 29 2011 1:24pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
on my 57 plate the lock broke and was replaced under warranty
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #326420 Thu Dec 29 2011 4:20pm
SVR575
Some times when i get fuel the car automatically locks and i cant close the petrol flap. SVR 2018 in Santorini Black.
Post #326430 Thu Dec 29 2011 4:42pm
