Home > Technical > Warning - Recovery point covers
Tim in Scotland
RR, something I was told if buying a used Disco was to make sure I checked 2 things as a priority........... The roof, because so many people drive into underground cars and don't realise they are scraping it and the other was that the Low ratio transfer case wasn't seized up with lack of use.
How many of you select Low ratio every month or so to make sure the system stays free and operational? All it needs is for you to start the engine, select Neutral and press the Low button every couple of months. If you are looking at a used Disco, Defender or RR (any version) check this, and if the warning light doesn't come on in the dash display then walk away................. £££££££££££££££££££££££££££££££££££'s to fix it! Even if you never intend to take your car offroad you should still give put it into Low ratio just to keep the system working OK. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #32632 Mon May 15 2006 4:13pm
