Home > General > How reliable are Range Rover Sports 3.6 TDV8?
Page 3 of 3 <123
Dawsey wrote:
Timf wrote:
Beware the slight lag at a junction/roundabout between putting your foot down & the take off - sometimes annoying but if you're used to it, its not a worry. Perfect car basically Smile
New to the RRS and after a TDV8
Excuse my ignorance but as a twin turbo does the first Turbo not feed the second Turbo eradicating lag?
As per the 35 BMW engines.
Dawsey
No, it's old fashioned one turbo per bank. The new TDv6 has a sequential turbo installation though. But then it's not a v8 so needs it! Wink 2012 SDV6 - it's missing a couple of cylinders
Post #323516 Thu Dec 01 2011 5:23pm
Dawsey
Cheers, so needs a 'kick start' to get going Thumbs Up
Dawsey
Post #323711 Fri Dec 02 2011 4:55pm
Dawsey
The problem isn't a turbo lag one, it's just that the gearbox defaults to 2nd gear to pull away if in D (automatic mode). If you select 1st manually then it just goes as soon as you ask. And goes well Thumbs Up
I've not yet found the TDV8 to suffer turbo lag as such. Even if it's in too high a gear it still pulls well. But then 472lbft at 2000rpm is never going to feel like its struggling! It produces a big chunk of that from low revs too. 2012 SDV6 - it's missing a couple of cylinders
Post #323715 Fri Dec 02 2011 5:17pm
Page 3 of 3 <123
