Home > Technical > Entry/Exit - seat move?
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
According to the manual the steering column AND the driver's seat should move on entry and exit. On mine (MY11 AB) only the steering column moves. Should I:
a) Stop reading the manual
b) Read some more
c) Complain
Post #321353 Tue Nov 15 2011 11:53pm
V8V Man
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
You raise an interesting point as I also own a MY11 HSE and on most occasions the steering wheel and seat do move to I guess what is called the "access mode" However, on some occasions the seat and steering wheel move a great deal more in that if I open the door and stay seated I am left in a significant recline!
Not yet raised this issue with the dealer but I can guess the response of NFF!
BTW, nice collection of Aston's you have there. If I'm not mistaken a Vanquish and a Virage V600? Smile MY2014 RRS Autobiography in Corris Grey, Black contrast roof and Cirrus interior, adaptive lights and side steps.
Gone - 2011 RRS HSE TDV6 Baltic Blue, Ivory/Ebony contrast stitching, Side steps, paddles, iPod/IPhone lead (works just fine with iPhone4), Adaptive lights
2011 Aston Martin V12 Vantage - Carbon Black Edition
Post #321355 Wed Nov 16 2011 12:02am
oldcro
Scotland
I've noticed the same myself (after philmw mentioned it) and wonder if the seat not moving is related to its position being stored in memory, rather than the seats last position. Must try and set the memory and see if the seat and steering wheel both move.
Post #321362 Wed Nov 16 2011 1:32am
essexfarmer
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
I find with mine that the steering wheel only moves up a fraction because I have it nearly all the way up anyway and the seat does not move at all because I need it all the way down while I am driving to get enough headroom. It's a good idea in theory but it's just a shame the wheel does not retract like it does in the FFRR. 12MY RRS Orkney Grey HSE Lux
12MY FF Santorini Black VSE
Post #321365 Wed Nov 16 2011 6:46am
Jimmy_75000
I never managed to have the seat to move.....Only the steering wheel does.... If anyone has an answer...!!!! Range Rover Vogue ‘17 TDV6
Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56
Post #321374 Wed Nov 16 2011 9:45am
^^^ Exactly the same here Smile
Try putting the seat up higher , then switching the car off. The seat should then drop to a more accessable height. ON THE WAY: BMW F21 M140i
Post #321378 Wed Nov 16 2011 10:19am
Jimmy_75000
Sad nope.... Range Rover Vogue ‘17 TDV6
Post #321424 Wed Nov 16 2011 4:42pm
Silly question I know, but do all models have the seat movement aswell as the steering wheel ?
I know on my E60 BMW only the wheel moved Confused
If yes, sounds like a connection problem Sad ON THE WAY: BMW F21 M140i
Post #321426 Wed Nov 16 2011 4:54pm
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
It moves both the wheel and seat on my model Cool
Naturally though it stands to reason that if you have yr seat in a position whereby it's relatively low and relatively far back from the wheel, the seat isn't going to move, but on mine (cos I'm a short ass) the wheel moves up and away and the seat down and back Thumbs Up Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #321466 Wed Nov 16 2011 7:38pm
philmw
Thanks all. Getting somewhere - the seat moves down (at the rear) on exit if raised - my normal position is fully down anyway so hadn't noticed.
Post #321488 Wed Nov 16 2011 11:17pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
As others report, It can only lower the seat if its in a high position . It also depends on which one of your 2 remote control keys you are useing itisme
Post #321678 Fri Nov 18 2011 2:44pm
SRE
Spain
Check the position of the Electric column switch, is it set to Auto ???? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #321679 Fri Nov 18 2011 2:47pm
muddywheels
Milk Float Man
The only time my seat moved was when I knocked the door controls by accident - pinned me to the wheel Shocked Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #321682 Fri Nov 18 2011 3:02pm
mse
The seat and steering wheel move relative to the normal set position you have them to eg, if them moving doesnt give you more room then it wont.
Also if you open the door or something like that, in the wrong order or too quickly it wont/doesnt work. Mike
2014 Facelift Discovery
Post #321880 Sun Nov 20 2011 7:18pm
rr5port
2010 Range Rover Sport TDV8 HSE Santorini Black
Have you stored your driving position into 1 of the 3 memory?
After turning the car off, (post 2010) and you open the door (if the position is stored in memory) then the seat should move back and down.
Post #322086 Tue Nov 22 2011 11:20am
