![]() | Home > Maintenance & Modifications > suspension arm bushes change |
just buy complete arms. they come with new bushes already fitted and a new ball joint.
tomma66 Member Since: 20 Aug 2011 Location: north east Posts: 33 ![]() ![]() |
thanks for the fast reply any info on where to get the parts as i think the front and the back need done and one thing im not short of is power tools so the bolts would,nt be a problem. |
Fronts lower are about £120 each, rear upper is about £85 each. New complete Bolt sets for all four is about £75.
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
bolts are a nightmare, had to cut mine off in the end. Best approach is defo to do the whole arm, IIRC i got them at 120 each |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I had both bottom arms replaced by a local independant, 2 arms £255.74 fitting £90.00 all plus VAT. Not worth rebushing, too tricky and time consuming. Good luck |
90+vat is a good price for fitting |
thanks for all the replys guys i have a mate that can change the bushes he has all the gear to do the job but how do i know if my car has ACE and roll stability as it is my first RRsport so im a bit of a novice. |
When you speak to Nick to order the parts, give him your VIN number and he'll tell you what you need to know. |
I think all the drop links are the same, as suggested call local dealers they will sort u out and will likely have them in stock. |
