Home > Technical > Nightmare introduction!
spidermac
England 2006 Range Rover Sport Supercharged Zermatt Silver
This is my first Range Rover after a selection of BMW ,Merc and Porsche I am starting to regret it! I bought a 2006 RR Sport V8 Supercharged 2 weeks ago and so far:
My remote keeps letting me down locking me out of the car.The passenger door won't open by key.
The passenger door is deadlocked and won't open.
The SATNAV only gives voice directions when the icon is touched.
Worst of all the car splutters when starting and every other journey the revs are limited to 4000 rpm and shudders at idle. The engine has been checked to have no faults and it is suggested that it is an airflow unit problem!
Not an ideal intro to the marque! Anyone have any remedies?
Post #320596 Wed Nov 09 2011 7:02pm
will_wonka
Location: Tminus 12 months for the RS Sport Supercharged!!
Re: Nightmare introduction!
Yep, take it to a dealer quick Exclamation
As the car is nearly 6 years old, did you get any worthwhile warranty Question Agreed not an ideal intro to the "marque" Whistle , but it could happen with any of the aforementioned as lots on here will confirm, one here for sure!
PS: Welcome Mr. Green L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
5 series for the miles Smile
RRS S/C factory built HST - Gone
45 others have been and gone!
Post #320597 Wed Nov 09 2011 7:06pm
spidermac
Booked in for next week but was just wondering if these were common problems with easy solutions.
Post #320600 Wed Nov 09 2011 7:12pm
will_wonka
.....rarely are things "easy" with such complex vehicles Sad L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now!
Post #320601 Wed Nov 09 2011 7:16pm
sweetafton
England 2011 Range Rover Sport Supercharged Santorini Black
What's the millage on your sport? Who checked the engine? Main dealer or indie? It might be worth resetting the car. Remove battery terminals and touch them both together and that will hard reset it. Only a thought. The passenger front door is the only door with a lock so any thing goes wrong with it you will not get into it so be careful mate. MY11 Autobiography supercharged. Santorini Black. Monaco interior. Rear screens. Privacy.
Gone MY08 Supercharged HST. Java black. Ivory premium interior. Rear screens. Privacy. Missed a lot.
Gone MY04 Discovery V8 Petrol ES Premium. Awesome.
Post #320602 Wed Nov 09 2011 7:25pm
On mine, the key works but you feel like your going to break it if you keep turning then It clicks and the door opens
Post #320606 Wed Nov 09 2011 7:47pm
mse
I would probably say if your new to the car this would be the reason you dont buy blind and do lots of digging into the car first! Mike
2014 Facelift Discovery
Post #320622 Wed Nov 09 2011 11:57pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
I wouldnt let this put you off mate, every model under the sun has a few lemons. To reasure you Ive had loads of Range Rovers and my 06 S/C Sport was my fav off them all, was also the most reliable. Thumbs Up
SAT NAV: I had a similar issue with the SatNav, if you play about with the settings you will find the option to turn on off voice commands, mine was set up the same when I first bought it.
Key : Sounds like a battery issue in the key, in order to operate the doors when u press the button the fob sends a encrypted code to the car, it gets that code from the car itself when its initially programmed. Its common for the batteries in these keys to fail to charge over time which means that there isnt enough power in the battery to send the code to the car to unlock. When its plugged into the ignition it gets power hence how its starts the car, but it should also recharge. New key is around £100 but will have to be programmed by LR dealer, ive heard of people managing to swap out the battery but it involves stripping the key and soldering in a new battery.
SPLUTTERING: I would suggest that its defo a problem with the engine, the car cant limit the revs without recording and engine fault. if its senses a minor fault more than three times in a journey with will drop into limp home mode the route cause may well be Fuel/Air but there is no way that the car wont record the route cause. Suggest you get it into a Dealer or specialists, dealers can be good and less costly than you think, alternatively ask on the forum for a specialist in your locale and give them a bell
Whats the mileage of the car and where did you get it from ?? Was it a private sale?
Post #320631 Thu Nov 10 2011 10:15am
Bobby
Consider yourself lucky! Smile
I paid premium for the Navigation System and I can only use it if I drive my beloved and expensive, top of the range RRS in Europe/UK! Laughing
It will not work anywhere else!! Twisted Evil Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #320633 Thu Nov 10 2011 10:22am
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
Definitely sounds like merely a settings issue on the sat nav.
Back into settings menu then two buttons with nav written on them, one with a cross thru it. Push the other one and that should be sorted Thumbs Up Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #320712 Thu Nov 10 2011 10:20pm
