![]() | Home > Maintenance & Modifications > HELP - Front passenger door skirt is hanging off... |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
If you mean the black plastic trim then it simply clips into place. You can buy clips pretty cheaply from the dealer, or possibly Halfords I think. I think there are a few posts on here if you search for +yellow +clip. The only difficulty is if the black plastic struts that the clips go into are broken on the trim then you either need to replace the trim or get them fixed, and aligned with the holes on the door. All in all a pretty simple job to do. I had a couple of broken struts (I was able to move them on the black trim once off) that I fixed with a bit of duct tape |
eshber Member Since: 04 Nov 2011 Location: London Posts: 27 ![]() ![]() |
Hi
V8 HSE CRUSADER Member Since: 02 Oct 2011 Location: driffield Posts: 163 ![]() ![]() ![]() |
i have got some plastic clips for the sills V8 HSE CRUSADER 2008
