![]() | Home > General > Transmission Fault & HDC Unavailable |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 ![]() ![]() ![]() |
On this side of the pond, calling it a "truck" isn't very well perceived... Range Rover Vogue ‘17 TDV6
smoftah Member Since: 10 Jun 2011 Location: Kent Posts: 30 ![]() ![]() ![]() |
My car also has this problem on start up where HDC fault and Transmission fault come up. If anyone has any info that would be great! |
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Where did you go DRDILL? Was it Riders? Have heard bad stuff about them. |
Yea heard that too. Sales where not to good but service was worse. Got family in truro so down there a fair bit. Brother in law works for MacSalvors and they had a lot of problems with them. |
krises27 Member Since: 03 Nov 2011 Location: Los Angeles Posts: 3 ![]() ![]() ![]() |
Ok thanks guys I appreciate the help, good note on your comment Martin, will post results when truck is done |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
I refer to mine as "the truck" at times. Or "the Sport". Or "the Rangie". Depends on the audience ![]() She even has a nickname but I shalln't share that on here... ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
if it's a TDV8 i assume "the SLUT"? |
bootz Member Since: 14 Oct 2011 Location: England Posts: 86 ![]() ![]() |
the SLUT??!! |
sam006 Member Since: 10 Sep 2011 Location: Kent Posts: 115 ![]() ![]() ![]() |
I just had near exactly the same problem, turned out to be an incorrect brake light bulb!! Range Rover Sport HSE and for a bit of weekend fun a S1 Lotus Elise with a few track biased additions! |
V6'r!! burn the witch!! |
Problem sorted!
So my Rover had 2 problems, 1 a faulty brake switch causing the brake light and traction light to come on so switch was replaced. 2 my compressor was going out therefor I had it rebuilt versus buying a new one. Its been 2 days since I picked up my rover and its running great... |
sorry to hear that DRDILL RRS gone
