Home > General > Washer pump question. 2008 Range Rover Sport.
jundrill
United Kingdom 2008 Range Rover Sport TDV8 HSE Siberian Silver
Gents,
I am having my 2008 RRS repaired after a front end 'shunt'.
My question is around the washer bottle that feeds (I assume) both the headlight washers and the windscreen washers.
When I press the button on my dash to either fire the windscreen washer jets or the headlamp washer jets are there 2 motors/pumps, 1 for each washer set or is there one pump/motor for both?
If 2 pumps/motors then where does the one sit for the headlight washers, in/near the bumper?
Thanks,
Jon
Post #319917 Thu Nov 03 2011 12:21pm
Martin
Site Administrator & Owner
If the same as the D3 (and I see no reason why it wouldn't be) then here are two pumps - one for the front/rear screen washers, and a separate one for the headlamp washers.
Plenty of threads on www.disco3.co.uk about, this might help you (it's about a retrofit but similar to refitting I'd imagine).
http://www.disco3.co.uk/forum/topic62199.h...Bwasher%2A Like this site? Buy some RRSPORT goodies to show your support!
Post #319918 Thu Nov 03 2011 12:30pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
yep I concur ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #320019 Thu Nov 03 2011 8:50pm
