Home > Technical > Whining/Wheel Vibration when lift off Accelerator Pedal
B14RYW
Members,
I have a 55 Plate 2.7 TD RRS and have a problem when i lift off the accelerator pedal
Its hard to describe but when the accelerator pedal is down, there is no noise and no vibration through the steering wheel
However, when i lift off the accelerator pedal (say to reduce speed but not hitting the brake pedal) i get a slight vibration through the steering wheel and there is a whining/droning noise from the front
Originally i thought it may be a wheel bearing or perhaps something wrong with the brakes
Someone suggested to me perhaps a fault with the Universal Joint?
I dont know anything about the mechanics tbh and have no idea where the universal joint would be if this was the problem.
Any advice/help/suggestions would be more than welcome as i dont want to stick it into the garage to get checked out and them not be able to locate the problem
Many thanks in advance
Barry
Post #319493 Mon Oct 31 2011 11:09pm
yeah.. under load it's fine but when free-wheeling it's vibrating... I'd check the drive train joints RRS gone
Post #319563 Tue Nov 01 2011 10:08am
B14RYW
thanks for this guys, really appreciate it
i am afraid i know nothing about mechanics so if i was to try explain to a mechanic where these are, will he know or can you give me some guidance?
are they expensive to fix?
am i okay to keep driving when its like this?
Post #319566 Tue Nov 01 2011 10:18am
B14RYW
Guys thanks very much for the feedback it defo sounds like I need to get it checked out
Does anyone know any Land Rover Specialists in Scotland I can take this too?
Don't really want to pay a dealers labour charge lol!!
Post #319756 Wed Nov 02 2011 9:08am
actros
had the same problem a couple of months ago ,it was the front diff pinion bearings, drain your diff oil if it is silver thats your problem,only did it on overrun fitting new diff cured it
Post #320423 Mon Nov 07 2011 10:39pm
B14RYW
Thanks for the feedback. Turns out it is my diff that's knackered so a new one arrived today from CWS and it gets fitted on Friday Smile
Just keeping my fingers crossed that problem solved once new diff is fitted
Post #320425 Mon Nov 07 2011 10:53pm
