![]() | Home > Maintenance & Modifications > RRS TDV8 Tuning Box Connection |
kennyt0804 Member Since: 18 Oct 2011 Location: Prudhoe Posts: 12 ![]() ![]() ![]() |
Hi Guys
Just under the dash right hand side of the steering wheel |
The unit ive have plugs into common rail diesel electrics
Never heard of any such connections.
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
If your unit intercepts the signal to the common rail, you need to locate the plug which on a TDV6 is on the front-end of the right-side rail (remove the top engine cover, rail runs along the side of the block). Not sure if the TDV8 is the same.
