Home > Technical > Realistic price for front ARB on TDV8 HST?
TenBob
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
I've just been quoted 'up to 2 days' at an independent to replace the knocking anti roll bar bushes on my TDV8 HST.
Doesn't sound right to me (or are cars with active cornering so much more difficult than non-ACE?)
Post #318291 Fri Oct 21 2011 11:06am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Nightmare job, chassis off in most cases LR authorise dealer somthing daft like 2 hrs to do the job where as in reality it's a day plus.
Anti roll bar itself is expensive too 1200 trade, plus vat if I remember correctly.
What's the issue? Is it leaking fluid?
Post #318301 Fri Oct 21 2011 12:23pm
x5pea
I just read that again it not the anti roll bar it's the bushes, my local guy charged me 200 inc parts lol
Post #318302 Fri Oct 21 2011 12:32pm
TenBob
Not sure yet, hoping it's just the bushes. I have LR extended warranty but not sure if ARB (not the bushes) is covered, waiting for stealer to call back.... Rolling Eyes
Post #318303 Fri Oct 21 2011 12:34pm
TenBob
Wow that's loads cheaper than the indy near me! Thanks for the info Smile
Post #318304 Fri Oct 21 2011 12:36pm
x5pea
You would know if it was fuid mate as u would notice it on the drive way and eventually it will give you a suspension error.
Post #318305 Fri Oct 21 2011 12:36pm
TenBob
Good point! I want my TDV6 back it was so much simpler!!!
Post #318306 Fri Oct 21 2011 12:38pm
Steuart64
Scotland 2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
A wee bit more work but local dealer is stating 5 hours and 3 for 4 wheel alignment on completion.
http://rrsport.co.uk/forum/topic24367.html?highlight=lr+warranty Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill
Ex - Audi A4 Cab 3.0TDi Quattro
Ex - Freelander2 SE TD4
Ex - CRV Auto
Post #318307 Fri Oct 21 2011 1:50pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Arb bushes £9,and it took me 10 mins to do 1 side and 50 to do the other,just because its harder to get the spanner in.And that was on axle stands not on a ramp at a comfy working height.Have you had the spacers put in before you change the Arb bushes?
Post #318351 Fri Oct 21 2011 5:41pm
TenBob
Are you talking about an ACE fitted car or standard suspension?
Post #318353 Fri Oct 21 2011 6:36pm
mrfixit
Standard,do you get a small consistant knocking(sounds as though its coming from the bulk head really)at low speed on small bumps/grids and the like,then it goes as you speed up.
Post #318361 Fri Oct 21 2011 7:39pm
TenBob
Yeah that sounds about right, big bumps don't seem to rattle it, nor does it rattle when travelling faster (above 50 ish)
Post #318390 Sat Oct 22 2011 8:01am
mrfixit
Ok sorry for late reply,we have a new puppy.Same thing on mine and they wanted £660 to replace the front wishbones,saying it was the bottom ball joints.I bought two ball joints and changed them and it didn't make the slightest bit of difference,they cost £36.I am prepared to bet anything that if you undid the arb bracket a bit and slip a 1 or 2mm washer up the back then tighten back up your knock will go.I used a C washer on each bolt cost under £1 and 10min job.
Post #318457 Sat Oct 22 2011 11:43pm
Supacat
Why would it need the 4 wheel alignment doing after just changing the arb bushes? There is nothing they should be touching that would upset the suspension geo.
Post #318472 Sun Oct 23 2011 11:55am
mrfixit
I don't know why a dealer quotes 5-6 hours nor do I profess to know more about the car than them.What I do know is you get a compression of the rubber in the ARB bush over time(hence the market for poly bushes(a harder compound).The knock that is caused by this is the ARB Arm itself hitting the bulk head as it has raised collars to prevent sideways movement,it is this collar that gives you the knock,so if you increase the clearance it gets rid of it.The collar and bulkhead were polished due to contact on mine.
Hopefully it will be clear with this little diagram. Thumbs Up
Sorry its not very technical I have a terrible case of man flu Embarassed
Hope it helps as its crazy that so many have suffered this for so long and recurrence after a so called fix but it really is as simple as I said earlier,if you havent got the notion to do it your self just nip it round to your local Mot station and ask them to do it. Thumbs Up
Atb
Steve
Post #318475 Sun Oct 23 2011 12:55pm
