Home > Faults & Fixes > Damage to Rear screen heater
ManixRR
2007 Range Rover Sport TDV8 HSE Stornoway Grey
I heard about this on another forum and wanted to see if anyone had used the product or can recommend another one
http://www.frostfighter.com/prt2100.htm
I am hoping to avoid the expense of replacing a perfectly good rear screen to get the heater working.
Any advice would be appreciated
Thanks Irish Range Rover Sport TDV8 2007
Post #317550 Sun Oct 16 2011 1:19pm
shepp
Hello manixrr
Can you physically see the damage, or does the rear heater not work. It is a common issue that the connector behind the spoiler corrodes. O cut mine out soldered and heat shrinked.
If it is physical damage, the kits do work. Maplins also do a repairkit
Post #317552 Sun Oct 16 2011 2:45pm
whealey
These are a fantastic idea!
Post #317596 Sun Oct 16 2011 8:22pm
ManixRR
shepp wrote:
Hello manixrr
Hi Shepp
I checked the connectors first and they are fine I can see the actual damage on the horizontal bars where the conductive material has been rubbed off by the previous owner
there are 3 bars working so I have quite a bit of masking up and painting with the frost fighter kit ( its dark brown the same as the original, Maplins one is silver apparently )
Still for 40 dollars it will all work again slightly better than the 993 euro for a new rear screen as recommended by two LR dealers here Irish Range Rover Sport TDV8 2007
Post #317755 Mon Oct 17 2011 11:56pm
