Home > Technical > Hybrid TV
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Hybrid TV
My MY58 has factory fitted TV but recently i have not been able to recieve any channels and maybe this is due to the digital switch over, was the factory unit fitted at this time analogue only and if so how do i get the system to tune into the new digital broadcasts?
Post #316968 Tue Oct 11 2011 11:36am
ronniet101
United Kingdom 2007 Range Rover Sport TDV6 HSE Buckingham Blue
hybrid tv
its called hybrid tv as its a combination of analogue and digital. the unit in my 2007 car works perfectly in cornwall (digital only) and around the country in areas with a mix of analogue and digital signals
Post #317128 Wed Oct 12 2011 12:47pm
leedsunited
Thumbs Up Thanks - i think i may have a problem with the tuner as it works sometimes and not at other.
Post #317152 Wed Oct 12 2011 3:41pm
simon1233
Leeds, when you have selected the tuner are you pressing the 'auto' button in the tuning section? (terrible description - but you know what I mean)
This should then tune in for any available channel that can be detected and is the only way to tune in digital channels. At least this is how it works in my FFRR Thumbs Up
Post #317157 Wed Oct 12 2011 4:20pm
leedsunited
Simon - Yes that is what i have always done but some times i just get a blank screen and no channels showing in the list Mad , i think i may have an intermittent tuner issue
Post #317204 Wed Oct 12 2011 8:30pm
simon1233
Leeds - I sometimes cannot get any channels on mine - If the signal is not so strong then the tuner does not seem to be able to get or hold onto a signal. The acid test is to see if you get the fault repeating in a known strong signal area.
Post #317217 Wed Oct 12 2011 8:51pm
leedsunited
Simon - That makes me feel a bit better that it is not just mine and a looks like a reception issue, i will try your suggestion. Thumbs Up
Post #317230 Wed Oct 12 2011 9:20pm
