Home > General > Where to get non-kinetic recovery ropes/straps |
Google Nylon Recovery Straps then follow the link to e-Bay. You want something with a safe working load in the region of 3 to 4 tonnes which will give you a breaking strain well in excess of even an RRS stuck on deep mud. Make sure the shackles you buy are also similar SWL , don't be tempted to buy small ones just because they are easy to handle, they will also break easily! RRS also has ideal storage for strops and shackles well wrapped in a jiffy bag or bubble pack so they don't rattle, under the small section of the rear seat so you don't need to leave them in a box in the boot, they can live under the seat for ever. Also BOW shackles would be better than "D" shackles. Nylon straps are easier to store than rope strops as you can wind them up neatly, they are easily available in any length you want as they are easy to make to measure and you want them with an eye in each end not as an endless loop. I have a kit similar to this for my Defender, it's more extreme than you want but it gives a good picture of a Bow shackle and a nylon strap! http://blog.promarkoffroad.com/2010/12/16/...and-nylon/
Thu Oct 06 2011 10:04pm |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
makes great sense.
Thu Oct 06 2011 10:19pm |
This is the sort of thing, maybe a little under SWL but it would do the job. http://www.ebay.co.uk/itm/Emergency-Recove...364wt_1413
Thu Oct 06 2011 10:25pm |
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 |
How does this one look for quality and value
Thu Oct 06 2011 10:46pm |
andaval Member Since: 23 Apr 2011 Location: London Posts: 9 |
Great stuff, guys - exactly what I was looking for and great tips on use and storage. This forum really knows its stuff.
Thu Oct 06 2011 11:28pm |
raadar Member Since: 07 Oct 2010 Location: sunshinecoastQ Posts: 38 |
am I wrong or do you have access to the likes of ARB or TJM offroad products from Aus. They are expert in the supply and manufacture of recovery equipment. For general recovery the rating of the straps we use here are generally set at 6-8tonne and the bow/D shckles are rated at 4.5tonne and upwards. A reputable manufacturer's advertised rating can be relied upon whereas a stated rating from a dubious ebay supplier may let you down (or worse) when you most need success.
Fri Oct 07 2011 2:55am |
Smarticus Member Since: 26 May 2005 Location: Northumberland Posts: 939 |
In the back of the RRS I prefer to carry a recovery strap with forged hooks built in. Most of these will clip into the Sports recovery point and the recovery point on many cars. In my experience the use of shackles add risks as these can come undone (or not be tightened properly) and can get stuck (so you cant undo them if the are over tightened). And a loose shackle flying through the air is a very dangerous thing.
Fri Oct 07 2011 5:49am |
