Home > Technical > cornering lights |
pko Member Since: 31 Jul 2011 Location: norfolk Posts: 193 |
Apologies for the duplicate post. Don't know what went wrong. |
Sat Oct 01 2011 7:05pm |
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 |
Never heard of them coming on when cornering on D3 or D4, I had a D3 and never had them on the car so can't comment further on that.
Sat Oct 01 2011 9:47pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
On mine they come on with the indicator and when cornering '08 RRS TDV8
Sat Oct 01 2011 9:54pm |
Not too sure of the later models but in the older ones, at speeds below 40 km/h (25 mph) and if the headlamps are on, the cornering lamps will switch on on the relevant side of the vehicle when the steering wheel is turned about 40 degrees and/or if the relevant direction indicators are used. Malaysia Boleh!
Sat Oct 01 2011 10:06pm |
Thanks for that guys. It seems as though l/r have changed the settings between my 09 model and the 11 model. Shame but I suppose that's progress.
Sat Oct 01 2011 10:20pm |
Sat Oct 01 2011 10:21pm |
So sorry for these repeat messages, I don't know why they are being repeated, so I'll not reply any more until I know what the problem is,
Sat Oct 01 2011 10:32pm |
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 |
Neee naw nee naw neee naw nee naw I can hear sweetafton approaching Have i got the busted controller?!?!!? 2009 RRS TDV8 Santorini Black Ivory / Anigre Privacy DVD & TV Side Steps |
Sun Oct 02 2011 7:52am |
Hopefully a single post this time. Does anyone know if they can be re programmed to come on independently of the turn indicators, as on the earlier models?
Sun Oct 02 2011 12:56pm |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
The cornering lights on my 2008 TDV8, which did not have active headlights, only came on with indicator and at speeds below 25mph. The cornering lights on my 2010 TDV8, which does have active headlights, come on without the indicators at speeds below 25mph when turning a fairly sharp corner. It seems they are programed in with the active headlamp system as an assist at low speeds/sharp turns. SWMBO owns this car I get to drive occasionally |
Fri Oct 07 2011 10:06am |
