Home > General > Suspension Problems.
PEACHY
I've come across a problem with my suspension - usual story and the same messages that I've read about on this forum.it started with a blown fuse - when i replace the fuse it allows me to higher & lower suspension as normal until the the vehicle warms up then the fuse blows. I then get different messages:vehicle will raise when system cooled down - normal height only etc. Where is the compressor located and can it be a DIY job or do I need stealership intervention ? Any advice welcome....... Big Cry 16MY Estoril Blue SVR.............
Post #315060 Sat Sep 24 2011 7:55pm
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
I have this suspension error intermittently on the dash.
Where is the fuse located? Which fuse is it?
Could my fuse of blown causing me this error as well?
Post #315067 Sat Sep 24 2011 8:58pm
PEACHY
Fusebox is located in the engine bay on v right next to v battery compartment. It's a 60amp - be aware it's not an ordinary fuse it took 24 hrs to get 1 from a local motorfactors. If the fuse has gone v chances are it's probably hiding something a little more sinister. Let me know how you get on . 16MY Estoril Blue SVR.............
Post #315068 Sat Sep 24 2011 9:06pm
