![]() | Home > General > Access Mode |
T8OOL Member Since: 16 Sep 2011 Location: Essex Posts: 242 ![]() ![]() ![]() |
When parking I put the car in access mode, sometimes it's fine. It lowers itself, other times it lowers then raises to normal then extended mode. I'm not sure if there is a specific way to set access mode.
sounds like it thinks it's bottoming out then accessing extended mode.
Are you locking it in access mode? Mike
Cheers, Ill book the car in RR Sport TDV8 09 Santorini Black with all the trimmings |
