Home > Technical > proble rr sport 2.7 td hse 2006
hem1979
Hello, I have a problem on a rr sport td v6 hse, togheter sporadically turns on the light engine, abs, esp, parking brake, suspension, hdc, automatic gear.
the car does not accelerate
fault codes with launch:
p0088 engine fuel rail / system pressure too high-
Auto Gear u2023 Received fault from external node
abs control module c1a00
Lost u0128 commuicatio with parking brake module
u0401 inalid date rceived from engine control / powertrain module cntrol
suspension u0416 invalid DataReceived veichle fro by dinamic control
instrument cluster medium U010 speedcan communication bus
u0159 losmmuniation assyt wth parking control
control on all terrain u401 invalid Received from control engine / powertrain control module
u402invalid DataReceived from Auto Gear.
Received date u416 invalid dynamic control
Received invalid date u0421 laughs level control
thank you, my English translator google
Post #313749 Thu Sep 15 2011 9:43am
ELD70
Check all rear brake lights or switch under brake pedal?
Post #313750 Thu Sep 15 2011 9:53am
BKHK
Battery, alternator or a bad earth?
Post #313766 Thu Sep 15 2011 11:09am
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
I was going to suggest poor Google translator Rolling with laughter Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #313770 Thu Sep 15 2011 11:15am
hem1979
ALTERNATOR CHARGED 13,40V BATTERY STARTED GOOD
PROBLEM MAYBE IS ONE ECU CAN BUS
WHERE CAN BE I FIND LOCATION ALL ECU?
LOCATION ECU D284?
SCUSEME MY ENGLISH GOOGLE TRANSLATOR
Post #313771 Thu Sep 15 2011 11:19am
iz6byo
2006 Range Rover Sport TDV6 HSE Buckingham Blue
di spiritosi ne hanno messi proprio tanti,
ti consiglio un bel passaggio da un conce Land.
i codici che hai scritto potrebbero essere solo casuali.
comunque prova a staccare la batteria per una notte e ricollegala.
ciao........
Post #313845 Thu Sep 15 2011 8:36pm
Okay Thumbs Up Laughing
Post #313853 Thu Sep 15 2011 9:19pm
hem1979
gia stato in concessionaria,ma non hanno idea,possono essere tutte le centraline e nessuna ,staccando la batteria non fa nulla,i codici non sono generici,sono proprio del difetto
Post #314807 Thu Sep 22 2011 10:02pm
iz6byo
la cosa stana č che di colpo non saltano pių centraline.
Confused
Post #315018 Sat Sep 24 2011 11:15am
Bloody foreigners Laughing
Post #315033 Sat Sep 24 2011 6:10pm
hem1979
il problema che una delle centraline ,quando gli pare,manda in tilt tutte le altre,possibile che non sia gia'successo nemmeno in land rover!?
Post #315124 Sun Sep 25 2011 12:44pm
Monky
2006 Range Rover Sport Supercharged HST Zermatt Silver
We had a similar problem to what you descrive on a TDV8 and it turned out to be the fuel pump.
Post #316406 Thu Oct 06 2011 6:06pm
hem1979
pompa nel serbatoio gia sostituita,pompa common rail scambiata con un altra ma uguale
Post #316446 Thu Oct 06 2011 10:13pm
