Home > Maintenance & Modifications > Cracked/Split Alloys!
toshers
Scotland 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Some of you may have read my post and know I'm looking to upgrade to 22" rims.
The problem is I've been trawling the usual sites, Ebay etc., and have noticed an alarmingly high incidence of cracked and split alloys in the 22" size. I realise these are copies of genuine designs but unless I'm mistaken LR don't actually produce any in this size?
If I do go down the 22" route does anyone have experience of what makes to avoid? There must be some replicas better quality than others?
I've always fitted genuine wheels and unless I can find a 22" replica wheel that's actually any good I may abandon the idea!
Overfinch do 22" wheels but they're out of budget!
Anyone point me in the right direction?...
Post #313872 Fri Sep 16 2011 12:45am
V8 andy
England 2009 Range Rover Sport TDV8 HSE Arctic Frost
Dont go down the 22" road,,ive taken loads of tyres off 22" which have been damaged,i did one for a customers who hit a pot hole & it had split straight down the middle,if he had been traveling at speed when he did it he would'nt be here now.
Andy. Gone,,TDV8 arctic frost,black leather,colour coded handles,rear entertainment,sunroof.
1980 Rolls Royce,shadow 2 in white.
Gone 07/57 TDV8 santorino,black leather.chrome handle's/mirror's.
Gone 02/52 FFRR vogue.
Post #313886 Fri Sep 16 2011 8:15am
NickM
On the other hand, I had 22'' Stormer copies for 3 years and they were perfect..granted no off road work, but 55,000 miles later....
Post #313929 Fri Sep 16 2011 3:05pm
A lot of 22 rims out there are not weight rated to be used on a rrs.
Check before buying that they are rated for a minimum of 1000kgs.
Plus make sure you use a premium tyre ie Toyo or similar, the cheaper alloys out there (on eBay) come with cheap tyres and they have weak tyre walls compounding the weaker alloy issue. Result, one pot hole equals bust rim RRS gone
Post #314066 Sun Sep 18 2011 11:51am
Tboner
Do not buy cheap 22" Rims and check loading are "real" and better still TUV approved 2014 5.0SC AB
Gone 5.0 SC
Post #314085 Sun Sep 18 2011 5:51pm
